Unable to connect Geodatabase
4087
14
12-28-2021 12:35 PM
vijaybadugu
I am using ArcGIS Pro to connect SQL Server Geodatabse 2017. Just want to upgrade it latest version. for this sde user required to login to the sde connection. I forgot the password of sde user and changed in sql server. after that, i tried to connect to Geodatabase, I am getting below error. I am able to connect to other databases and able to create new enterprise database. How to troubleshoot the issue ?
George_Thompson
Esri Notable Contributor
Have closed and re-opened ArcGIS Pro?
Does the password have special characters?
--- George T.
vijaybadugu
I reopened ArcGIS Pro. Nothing worked.
Password does not contain any special characters.
George_Thompson
Can you provide clarification for the "no"?
"no" to special characters or "no" to both?
--- George T.
vijaybadugu
George_Thompson
Ok, thanks for that.
What is the version of ArcGIS Pro?
You said that you can connect to other geodatabases on the same SQL Server 2017 instance, correct?
Can other DB users connect on that same EGDB?
--- George T.
vijaybadugu
What is the version of ArcGIS Pro? 2.9
You said that you can connect to other geodatabases on the same SQL Server 2017 instance, correct? Yes
Can other DB users connect on that same EGDB? No
George_Thompson
Ok, so can you connect via SSMS to the SQL Server DB using the SDE user credentials?
--- George T.
vijaybadugu
Yes . I’m able to connect from SSMS
George_Thompson
Have you restarted the machine (reboot) that ArcGIS Pro is installed on?
It may be best to work with Esri technical support on this issue.
--- George T.
