Unable to connect Geodatabase
4082
14
12-28-2021 12:35 PM
vijaybadugu
I am using ArcGIS Pro to connect SQL Server Geodatabse 2017. Just want to upgrade it latest version. for this sde user required to login to the sde connection. I forgot the password of sde user and changed in sql server. after that, i tried to connect to Geodatabase, I am getting below error. I am able to connect to other databases and able to create new enterprise database. How to troubleshoot the issue ?
vijaybadugu
I restarted the system. And created a case for it .
vijaybadugu
Is there any other alternative to create new enterprise database and copy existing one to new database ?
George_Thompson
Esri Notable Contributor
Random question: Is this DB a restored one in SQL Server?
If so, was the name changed during the restore?
--- George T.
vijaybadugu
No.
DougGreen
Have you updated the password in the connection set up in your ArcGIS Pro project? Right-click > Connection Properties.
