Trouble Deleting Domains
10011
19
12-02-2011 09:03 AM
TomKoritansky
Hello everyone,
I'm having trouble deleting a domain list from my file geodatabase.  When I try to delete to domain I get an error that says:
"Failed to a delete domain from the database.
The domain was not found.
The domain was not found. [name of domain]"
I also cannot add any new entries to the domain or change the domain name and description; I get a similar error that says:
"Failed to update a domain.
The domain was not found."
The domain is not attached to any attribute fields.
One thing I noticed was that if I try to edit the domain name a box symbol appears at the end of the domain name when cursor is in the window to type more text.
Any suggestions?
shan_sarkar
Was the database was created in version 10.5?
Is it being used in some services in ArcGIS Online or ArcGIS Server?
~Shan
GeorgiyYaroslavtsev
Yes, it was created in 10.5 version.
And it is not using and wasn't used in Online or Server services, but feature classes from geodatabase is planned for publication to the Portal in the future.
shan_sarkar
Is the database stored locally on the machine or on a shared network drive?
~Shan
GeorgiyYaroslavtsev
It's on the shared network drive.
shan_sarkar
Just for testing purposes can you copy it locally and then try to delete the domain?
~Shan
GeorgiyYaroslavtsev
Sorry for delay...
I have not access to do this locally.
But I think, explanation of the problem by Rex Robichaux corresponds to my situation.
Actually I have copied domain name for this domain from Excel table.
RexRobichaux2
Depending upon the way the domains / domain names were originally entered I have seen this behavior when a domain exists that has a carriage return present. This typically occurs when domain names are copied from sources like Microsoft Excel where carriage returns may be hidden and often times they are not immediately visible when viewing domain properties within ArcCatalog. There is a defect addressing this behavior for Oracle enterprise geodatabases (but it might well affect file geodatabases as well). If values have been copied / pasted opposed to manually entered for domain names- I'd consider this a high possibility:
BUG-000091839:
Updating or deleting a domain created with a carriage return returns the error, "Failed to update one of the domains. The domain was not found."
Bartee_Emily__KYTC_
Thank you for explaining the why - that is helpful in avoiding this in the future.  That being said, how do we delete the domain?  Is it possible?  I'd appreciate any feedback and thank you,
Emily
curtvprice
You may want to consider using X-Ray to dump the geodatabase structure, modify it, and reload the data into the fixed copy.
X-Ray for ArcCatalog
https://www.arcgis.com/home/item.html?id=9ea218ff575f4a5195e01a2cae03a0ae
by Anonymous User
Not applicable
Hi, I have the same problem. Is there a good solution or workround for this? Because the Geodatabase I manage and cause this problems is with replica and very large and important to just export and import for X-Ray to change the structure.
BR,
Tiina
