Trace Tool Stops Working
3530
10-29-2015 10:52 AM
GregoryElwood1
I just need to vent - the Trace Tool in my ArcMap document has stopped working. Completely. Nada. Zippo.
I've tried all the usual remedies...closing the .mxd file, logging out, restarting the machine, opening the feature class in a blank map...nothing...it's beyond frustrating...
...I really wish the software would not do these sort of things...
LukeSturtevant
Is it a feature class in a geodatabase? Have you tried exporting to shapefile and editing or vice versa if it is a shapefile now?
Also, I'm sure you may have already checked the different threads, but here is a thread that has a lot of workarounds that people have used.
DanPatterson_Retired
Sometimes these things are beyond worldly explanation ... if so then you have to rely on that which you don't understand ... Trace Tool Back From The Dead
