The option ???disconnect??? is grayed out,
1587
02-01-2013 01:05 PM
JamalNUMAN
Legendary Contributor
The geodatabase administration dialog box is accessed by the administrator to disconnect all the users but sounds that the ???disconnect??? option is not active
[ATTACH=CONFIG]21348[/ATTACH]
What might be the issue here?
Thank you
Best
Jamal
Jamal Numan
AsrujitSengupta
Its because you have selected all the connected for disconnecting, which includes your connection to the sde geodatabase too. Just select the connection you want to disconnect and you will be able to do so.
Regards,
AsrujitSengupta
Regards,
JamalNUMAN
Regards,
Many thanks Asrujit. It work fine now
[ATTACH=CONFIG]21357[/ATTACH]
Best
Jamal
Jamal Numan
