The ???manage replica??? is grayed out and the ArcGIS says: ???replica with the same name a
3039
02-02-2013 10:24 AM
JamalNUMAN
Legendary Contributor
The ???manage replica??? is grayed out and the ArcGIS says: ???replica with the same name already exists???,
I???m wondering how the ???manage replica??? is deemed (a feature class of geodatabase is on the table of contents and refresh is applied) while creating replica ends up with ???replica with the same name already exists???
[ATTACH=CONFIG]21363[/ATTACH], [ATTACH=CONFIG]21364[/ATTACH], [ATTACH=CONFIG]21365[/ATTACH]
How to better access the list of replicas created between two SDE geodatabases?
what might be the issue in this case?
Thank you
Best
Jamal
Jamal Numan
AsrujitSengupta
Right-Click on the Child Geodatabases's connection (Sa_S2.sde)--> Distributed Geodatabase-->Manage Replicas--> check whether a Replica with the same name already exists there!
[ATTACH=CONFIG]21390[/ATTACH]
If there is a Replica already present with the same name--> Unregister the replica and then try creating the new Replica...
Regards,
AsrujitSengupta
Regards,
by Anonymous User
Not applicable
Original User: Jamal432@gmail.com
Regards,
Perfect. Many thanks Asrujit. It did work
The screenshot is great tool to convey the ideas
All the best
Jamal
