The error number from ArcObjects is: '-2147220735'. The error message from ArcObjects is: {Unable to create object class extension COM componen
6770
8
06-23-2023 11:09 AM
spiderman90
hello ,
I am trying to importing XML Document schema into the working File Geodatabase.
I have used Fme and tried  also import xml workspace document at ArcGis pro but I got this error
The error number from ArcObjects is: '-2147220735'. The error message from ArcObjects is: {Unable to create object class extension COM component Then feature class  name
How could I solve this problem ?
George_Thompson
Esri Notable Contributor
That sounds like there may be something related to ArcFM in the schema you are importing?
When I see that error it usually is related to ArcFM or a custom COM component in the source database.
--- George T.
spiderman90
What does it mean with custom component in database ?What should I do to solve this problem ?
George_Thompson
Custom COM is usually from some sort of 3rd party program (non-Esri). That specific error code is for "dataset not found".
What version of ArcGIS Pro are you using?
What version of ArcGIS client created the XML file?
Can you copy over a feature class from the old DB to the new DB without any issues?
What type of data is in the XML file (or old geodatabase)?
Is the source data using a geometric or utility network?
I could potentially test it on my side if you are willing and able to send me the XML file. No promises of a solution, but another set of eyes.
I know that you are trying to use XML, but want to see if the results are the same.
--- George T.
spiderman90
i am preparing the data to migrate it to use into ArcGis pro .
the source data is geometric network
and I have exported xml from ArcCatalog for arcmap .,ArcGis Enterprise 10.8.1
the source data is electric network
i believe ,it will be hard to send xml file because the data belongs to my company .but could you provide me some tips that I could try to fix the problem ?
spiderman90
Is there any ideas that could help me ?
MarceloMarques
Esri Geodatabase Classic Geometric Network is supported only with ArcMap, and if you have an ArcFMized Geodatabase then also is only supported with the ArcFM extension for ArcMap.
ArcGIS Pro customers need to migrate to ArcFM XI and the new Esri ArcGIS Pro Utility Network + Branch Versioning Solution.
https://pro.arcgis.com/en/pro-app/latest/tool-reference/appendices/unavailable-tools.htm
Geometric Network
Note:
Geometric networks are a read-only dataset in ArcGIS Pro. ArcGIS Pro includes two capabilities you can use to manage, model, and analyze network systems: the Trace Network and the Utility Network.
https://pro.arhttps://myarcfm.schneider-electric.com/myarcfm/s/arcfm-editor-xicgis.com/en/pro-app/3....
- you must UnArcFMize your geodatabase, then migrate the geodatabase schema, update the ArcSDE Geodatabase Repository using ArcGIS Pro then convert your Classic Geometric Network to a Trace Network.
- you cannot use a Trace Network with ArcFM XI
- ArcFM XI works only with ArcGIS Pro and you must migrate to the ArcGIS Pro Utility Network + Branch Versioning.
https://pro.arcgis.com/en/pro-app/3.0/help/data/utility-network/what-is-a-utility-network-.htm
For more information about ArcFM XI for ArcGIS Pro see the Schneider Electric website.
| Marcelo Marques | Esri Principal Product Engineer | Cloud & Database Administrator | OCP - Oracle Database Certified Professional | "About: In 1992, I embarked on my journey with Esri Technology, and since 1997, I have been working with ArcSDE Geodatabases, right from its initial release. Over the past 33 years, my passion for Spatial Databases and GIS data has become a central part of my career.." | “ The mountains are calling and I must go.” – John Muir |
spiderman90
@MarceloMarques Thanks for explanation ,
At my company , they migrate from ArcFM to UT-Editor since couple of years
but I believe now ,it is still some data relates to ArcFm.
1.What  should i do to UnArcFMize ?
2.i would like to sure ,Does UT Editor use only classic geometric network ?
3.as info : source file is Esri geodatabase
MarceloMarques
[Marcelo]:
Remember the ArcFM Solution Object Converter (schneider-electric.com)
For further assistance ArcFM Support Page https://arcfm.my.site.com/myarcfm/s/login/  you can create a support account and create a ticket or search the ArcFM forums.
[Marcelo]: I am not familiar with UT Editor, and you will have to reach out to the vendor of that software extension to inquire about it.
UT for ArcGIS – VertiGIS Support
[Marcelo]: you need to check each featureclass and table type.
I hope this helps.
If you continue to experience an issue to migrate your data then open a Esri Technical Support ticket, if you still require further assistance then Esri Professional Services can help your company to migrate your data.
Esri Services | GIS Professional, Training & Support Services
