.tar extension help
10563
11-07-2012 09:22 AM
DanielBigelow1
I'm trying to open some land cover data in Arc that has a .tar file extension. As far as I can tell from online documentation and forums, this extension means that the files are compressed and need to be extracted. Could anyone give me a pointer on how to go about extracting the data? Specifically, can i do this in Arc? I'm working in a university computer lab, so I can't download any extraction programs such as 7zip. Any help would be much appreciated.
Data can be found here: http://www.fsl.orst.edu/pnwerc/wrb/dwnld_lulc1990.html, the first option being the one I'm trying to use.
Best,
Dan
MelitaKennedy
Esri Notable Contributor
Hi Dan,
Does the computer have any type of zip program? They should all support tar files. A tar file is just a collection of files; not really compressed. A tar could then be compressed using a zip or compress program. This one appears to have been compressed with WinZip or something similar after the files were collected together into a tar file.
See if MKS is installed by opening a DOS window and typing tar. If you get a command usage line back, type
tar -tvf C:\path\to\file\filename.tar
or
tar -tvf filename.tar
if you're in the same directory as the file to see the files inside the tar file.
To extract the files:
tar -xvf filename.tar C:\path\to\where\you\want\the\raster
The tar command is a unix/linux command so if you have a colleague who uses linux, ask them to extract the file. (the data's about 25mb, so a little big to email around)
Melita
