Tables participating in a replica generated empty,
4093
7
06-16-2013 07:47 AM
JamalNUMAN
Legendary Contributor
I wanted to create a replica from an ArcSDE geodatabase (parent) to a file geodatabase (child) but sounds that the tables replicated on the child geodatabase are found to be empty. Other features classes are replicated successfully.
[ATTACH=CONFIG]25292[/ATTACH], [ATTACH=CONFIG]25293[/ATTACH]
What might be the issue here?
Why tables participating in replica are found to be empty on the child geodatabase?
Thank you
Best
Jamal
Jamal Numan
AsrujitSengupta
Jamal,
As mentioned in the link: http://support.esri.com/en/bugs/nimbus/TklNMDQwMjgz
"This is a expected behaviour", so I don't think there will a fix out for this.
The Direct method that you are looking for is as follows:
Use distributed geodatabase toolbar in ArcMap to create the replica
The above method will replicate the records too.
Regards,
MarcoBoeringa
MVP Regular Contributor
Jamal,
I think Jake Skinner (ESRI) described the issue and solution in this thread:
http://forums.arcgis.com/threads/46668-Non-spatial-table-replication
The screenshots in that thread are no longer there, but the setting Jake is referring to is the one under:
Expand Feature Classes and Tables (optional)
in the Create Replica dialog. You need to choose "ALL_ROWS" instead of "USE_DEFAULTS" to add all records in case of tables.
by Anonymous User
Not applicable
Original User: Jamal432@gmail.com
Jamal,
Thank you Marco for the help,
Unfortunately, I tried it but sounds not to work. The resulted table in the replica is still empty.
[ATTACH=CONFIG]25295[/ATTACH], [ATTACH=CONFIG]25296[/ATTACH]
Just in case it works, do we need two replicas (one for feature classes and one for tables) to replicate all the data from the ArcSDE geodatabase to the file geodatabase?
Best
Jamal
MarcoBoeringa
Jamal,
I haven't yet had time to test the replication of a table myself, but this Help page says:
"For tables the default filter is Schema Only; only the schema for the table will be replicated. To apply a filter to a table you must first create a table view setting desired filters. You can then use this as input into the Create Replica tool. See the Make Table View for more information. For more information on filters and replication see Preparing data for replication."
It seems you may need to make a Table View first, and use that as input for the Create Replica tool.
I don't know the reason for this, except maybe that most (or some) stand-alone non-spatial tables part of geodatabases, may actually be very big and actively maintained tables from business systems, for which it is better to only replicate a selection of the data really necessary in the child replica, to avoid excessive data traffic between parent and child.
by Anonymous User
Not applicable
Original User: asrujit
Jamal,
This is by design.
Please have a look at the below link for more details:
[ NIM040283 - Using GP tool (create replica) to create replica and set ALL_ROWS for expand feature classes and tables, the attribute table only has its schema replicated.]
You can also have a look at the below post for a good workaround:
http://forums.arcgis.com/threads/48195-Create-Replica-on-SDE-Table?p=166604#post166604  (look at the last post)
Hope this helps!
Regards,
by Anonymous User
Not applicable
Jamal,
This is by design.
Hope this helps!
Regards,
Thank you very much Marco and Asrujit for the help,
Sounds that there is no direct way to have the non-spatial data replicated the same way as for the spatial data.
Does this behavior continue in 10.2?
This is the second challenging issue I got regarding the ArcSDE geodatabase. The first one was how feature classes can be added to an existing replica. In this case, no direct solution is available neither.
Best
Jamal
AsrujitSengupta
Jamal,
Regards,
by Anonymous User
Not applicable
Jamal,
Regards,
Many thanks Asrujit for the prompt help,
As you have already recommended, I used the �??distributed geodatabase�?� toolbar to create the replica and it worked fine
[ATTACH=CONFIG]25315[/ATTACH], [ATTACH=CONFIG]25316[/ATTACH], [ATTACH=CONFIG]25317[/ATTACH]
Hope that they will fix the behaviour of the geoprocessing tool in 10.2.
All the best
Jamal
