Strange editing results
900
01-10-2012 02:56 PM
Thomastang
There are two attached MXD file, test.mxd and test1.msd. They are both using same geodatabase and same feature. If you edit in test.mxd, the polygon will distort, while the test1.mxd will has no this problem.
Does anyone can explain why?
Thomas
____________________________________________________________
Before Editing
[ATTACH=CONFIG]11065[/ATTACH]
After mirror
[ATTACH=CONFIG]11066[/ATTACH]
