Start Editing Error
1292
03-31-2014 06:56 AM
JoshuaDamron
Greetings,
I am having an issue when I start an editing session.  Often when I select "Start Editing" (either via the Editor drop down on the tool bar or via a right click on the layer>edit>start editing) I will receive an error message like this example:
[ATTACH=CONFIG]32645[/ATTACH]
Normally when I see this error message it would be telling me there is a schema lock on the file because someone else is editing in the same file geodatabase.  However with 10.2 this error pops up when I am the only one using the file.  I have even moved the file or started a new file geodatabase from scratch on my C Drive to make sure another user is not an issue.  The weird thing is that I can see the schema lock, and by all appearances it is generated by my computer (When I close out of ArcGIS I can watch the lock go away, then I reopen the .mxd and it reappears)... which since I only have one .mxd open that would mean that my ArcGIS is accessing the file, locking it then when I go to edit the file it is reading its own lock and not allowing me to edit.
When I had 10.1 I would occasionally have this issue, it is much more frequent now in 10.2 (once a week).  I typically resolve it by restarting my computer and this will often (not always) clear the issue.
Any thoughts on what could cause this lock issue to occur?
MarkBoucher
Honored Contributor
I've found I can get lock issues if I'm looking at the data through some other software: Arc Catalogue, Windows Explorer, etc. Make sure they are closed and see if you still have an error.
