St_Geometry spatial indexes are not creating S###$_IX2
1628
06-12-2013 04:31 AM
MatjazHabic
We have  following configuration Oracle on RHEL linux:
  **********************ArcSDE install summary:**********************
  ArcSDE 10.1 Oracle_11g (64-bit) Install Location:
  /home/sde/sdeexe101
  Service Pack / Patch / Hot Fix Found:
  SP-ID: ArcSDE 10.1 Service Pack 1
$ uname -a
Linux xxxxxx 2.6.18-274.el5 #1 SMP Fri Jul 8 17:36:59 EDT 2011 x86_64 x86_64 x86_64 GNU/Linux
As described  in "NIM084235 - St_Geometry spatial indexes are not creating S###$_IX2 indexes on the IOT SP_ID column"   for "ArcGIS 10.1 SP1 for (Desktop, Engine, Server) PostgreSQL and Parcel Editing Performance Patch" (http://support.esri.com/en/downloads/patches-servicepacks/view/productid/66/metaid/1941)  there is missing index on SP_ID column.
Where can be found patch for Oracle ?
regards
Matjaz
VinceAngelo
Esri Esteemed Contributor
If you're looking for patches, you really should be talking to Tech Support.
- V
by Anonymous User
Not applicable
I encountered this problem this morning and came up with this script, hopes it helps someone!
// Lars Nordvall Triona AB
/* Use this script to create S###_IX2 indexes on spatialindex tables in ArcSDE 10.1 */
/* Workaround for NIM084235 http://support.esri.com/en/bugs/nimbus/TklNMDg0MjM1 */
set serveroutput ON;
declare
 cnt number(38);
 sqlStr varchar2(255);
 spatialIndexTable varchar2(32);
 indexName varchar2(32);
 type cref is ref cursor;
 c1 cref;
begin
 cnt := 0;
 sqlstr := 'select table_name from user_tables where table_name like ''S%_IDX%'' order by 1';
 DBMS_OUTPUT.PUT_LINE(sqlStr );
 open c1 for sqlstr;
 LOOP
  fetch c1 into spatialIndexTable;
  EXIT WHEN c1%NOTFOUND;
  cnt := cnt + 1;
  indexName := substr(spatialIndexTable,0,length(spatialIndexTable)-1) || '2';
  sqlStr := 'create index ' || indexName || ' on ' || spatialIndexTable || '(SP_ID)';
  DBMS_OUTPUT.PUT_LINE( sqlstr );
  EXECUTE IMMEDIATE sqlStr;
 end LOOP;
 close c1;
 DBMS_OUTPUT.PUT_LINE('Index creation finished (' || to_char(cnt) || ' indexes created)');
end;
ForrestJones
Hi Matjaz,
The fix/patch for this issue is available at the link you sent (http://support.esri.com/en/downloads...66/metaid/1941).
To upgrade/patch your database on linux, just install the windows setup on your client, connect to your linux database using a direct connection and run upgrade.
by Anonymous User
Not applicable
I tried the patch and it did not have any effect on my Oracle installation.
It's for PostGIS?
MarcoBoeringa
It's for PostGIS?
Looking at the installed files, even though PostGreSQL is specifically mentioned in the title of the patch, this patch also seems relevant for Oracle, as files for the other DBMSs are installed as well. Fixes for the other DBMS are related to Parcel Editing.
Do mind the caveat though (see the patch link😞
"If you installed the ST_Geometry type in your Oracle or PostgreSQL database, upgrade the type after you install the ArcGIS 10.1 SP1 for (Desktop, Engine, Server) PostgreSQL and Parcel Editing Performance Patch. See the topic specific to your DBMS for instructions: ..."
