ST_GEOMETRY  problem on Oracle RDBMS 11g R2 11.2.0.3
22164
22
12-13-2012 09:02 AM
irishadar
We've installed ARCSDE 10.1 on Oracle RDBMS 11g R2 11.2.0.3 in Solaris 10 box.
Unfortunately we can't get the ST_GEOMETRY to work.
We keep getting the following error even though every thing configured by the book.
Error starting at line 2 in command:
select st_point(0,0,0) from dual
Error report:
SQL Error: ORA-28595: Extproc agent : Invalid DLL Path
ORA-06512: "SDE.ST_GEOMETRY_SHAPELIB_PKG",line12
ORA-06512: "SDE.ST_POINT",line176
28595. 00000 - "Extproc agent : Invalid DLL Path"
I've enclose my DBA notes as well.
has any one got st_geometry working on oracle 11.2.0.3 on unix ?
help would be much appriciated
iris hadar
IAA
irishadar
I've run the lld command, this is the results:
SDE /var/opt/esrilibs 12 > ldd libst_shapelib.so
        libclntsh.so.10.1 =>     /u01/app/oracle/product/11.2.0/dbhome_1/lib/lib
clntsh.so.10.1
        libCrun.so.1 =>  /usr/lib/64/libCrun.so.1
        libnnz11.so =>   /u01/app/oracle/product/11.2.0/dbhome_1/lib/libnnz11.so
        libkstat.so.1 =>         /lib/64/libkstat.so.1
        libnsl.so.1 =>   /lib/64/libnsl.so.1
        libsocket.so.1 =>        /lib/64/libsocket.so.1
        libresolv.so.2 =>        /lib/64/libresolv.so.2
        libgen.so.1 =>   /lib/64/libgen.so.1
        libdl.so.1 =>    /lib/64/libdl.so.1
        libsched.so.1 =>         /usr/lib/64/libsched.so.1
        librt.so.1 =>    /lib/64/librt.so.1
        libc.so.1 =>     /lib/64/libc.so.1
        libaio.so.1 =>   /lib/64/libaio.so.1
        libpool.so.1 =>  /usr/lib/64/libpool.so.1
        libm.so.2 =>     /lib/64/libm.so.2
        libmp.so.2 =>    /lib/64/libmp.so.2
        libmd.so.1 =>    /lib/64/libmd.so.1
        libscf.so.1 =>   /lib/64/libscf.so.1
        libxml2.so.2 =>  /usr/lib/64/libxml2.so.2
        libnvpair.so.1 =>        /lib/64/libnvpair.so.1
        libexacct.so.1 =>        /usr/lib/64/libexacct.so.1
        libdoor.so.1 =>  /lib/64/libdoor.so.1
        libuutil.so.1 =>         /lib/64/libuutil.so.1
        libpthread.so.1 =>       /lib/64/libpthread.so.1
        libz.so.1 =>     /usr/lib/64/libz.so.1
        /platform/SUNW,Sun-Fire-V240/lib/sparcv9/libc_psr.so.1
        /platform/SUNW,Sun-Fire-V240/lib/sparcv9/libmd_psr.so.1
I've also run the command "ldd  -v libst_shapelib.so |grep 'not found'"
it came back with nothing .
I think it is simply not working on 11.2.0.3.0 for some reason.
iris
irishadar
problem solved 🙂
we realy don't know what solve it but here are the three major changes:
1.You must take the libst_shapelib.so from the unix installation and not from the "AcGIS for Desktop" as documented by ESRI.
2. you must have both extproc.ora  and old configuration "LISTENER.ORA+TNSNAMES.ORA".
3. the libst_shapelib.so must be in oracle root installation (oracle recommendation)
thank you for your time
iris
VinceAngelo
Esri Esteemed Contributor
I don't have the time to go through a 11.2.0.3 install right now, but I have doubts
about your solution as a recipe for others:
+ My ArcSDE for Oracle 11g libst_shapelib.so is dependent on libclntsh.so.11.1,
and the 10g install is dependent on libclntsh.so.10.1
+ Can you provide a URL to the instruction to use the Windows DLL on Unix?
+ The Oracle docs say that only changes to extproc.ora are necessary
+ Your distributor was wrong to say that the ArcSDE application server was
unnecessary.  While you certainly don't need to run it, the application server
install is the location that service packs must be applied, so you should keep it
on the database server, preferably as the location from which the DLL is obtained.
Removing the install hides the fact that Esri components are installed on the
system, and makes it more difficult on a future admin/DBA to understand what
has occurred previously.
- V
irishadar
I completely agree with you since as I mentioned in my reply , we realy don't know what solve it , I simply pointing the changes that made the difference.
I didn�??t mentioned it before but this was a completely new installation , no ARCSDE was ever install on it , so maybe that's way we don�??t have  the dependencies  you have (I've enclose ours in my last reply) .
In any case this is the URL: http://resources.arcgis.com/en/help/main/10.1/index.html#/A_quick_tour_of_setting_up_a_geodatabase_i...
Under "Setting up a geodatabase in Oracle" you can find these line:
"The ST_Geometry library can be found in the DatabaseSupport directory of your ArcGIS client."
Regarding the extproc.ora , I know this is what's documented but , it didn�??t work till we added the "old style" configuration as well .we plan on testing it again with only the extproc.ora config, once we finish making some benchmarks.
I accepts your suggestion regarding the" ArcSDE application server " and will pass on to my DBA .
Thanks again for all your effort to help us, it is really appreciated.
Iris hadar
EmadAl-Mousa
i have the same "EXACT" problem.
Our environment:
Database release: ORACLE11G (11.2.0.3)
ArcSDE Geodatabase 10.1 SP1
Server: IBM AIX 6.1
error received:
ORA-28575: unable to open RPC connection to external procedure
ORA-06512: at "SDE.ST_GEOMETRY_SHAPELIB_PKG",line 1325
ORA-06512: at "SDE.ST_GEOM_UTIL",line 823
i have configured the external procedure per ESRI & Oracle documentation, and still received the same problem.
Also, i have configured the (tnsnames and listener) as a last resort, and still having the same issue.
i have tried this in multiple oracle instances with release "11.2.0.3"
i think this is a serious issue and ESRI should look into it and provide technical article if possible.
if anybody has any suggestions, it will be appreciated.
irishadar
We eventually went down to oracle 11.2.0.1 but we also made the following changes , so maybe this will help you:
1.Take the shape.so lib from the arcsde installation for unix and not from arc catalog as describe in the documentation ( we have tested it twice to be sure , the file from windows arc catalog is not working ).
2.Make sure that the path is ok , using these syntax,
   �?�SELECT * FROM USER_LIBRARIES
3.We've followed these steps provided by our local distributer , step by step :
     a.Modify your extproc.ora as follows: SET EXTPROC_DLLS=ONLY:�?�.�?�(path)�?�.�?� libst_shapelib.so
     b.Re-create the libraries: $sqlplus sde/sde SQL> create or replace library ST_SHAPELIB as '�?�.�?�(path)�?�.�?� libst_shapelib.so '; Library created.
    c.Make sure that the dlls are valid. SQL>select * from user_libraries; Make sure it is pointing to the correct path and is valid.
    d.Compile st_geometry_shapelib_pkg SQL> alter package sde.st_geometry_shapelib_pkg compile reuse settings; Package altered.
    e.Creating the library causes dependent object to become invalid. Execute the following command as the SDE user (you may need to grant the execute privilege on sys.utl_recomp to user SDE):
          i.As sys user, grant execute on SYS.UTL_RECOMP TO SDE. SQL> GRANT EXECUTE ON SYS.UTL_RECOMP TO SDE;
          ii.As SDE user, recompile. SQL> EXECUTE sys.utl_recomp.recomp_serial('SDE');
    f. Verify all objects are valid as SDE user. SQL> select object_name, object_type from user_objects where status = 'INVALID'
     g.Remove for now the "tnsnames+listener" config and see if it works
hope this will work for you
iris hadar
EmadAl-Mousa
Thanks alot iris,
if you don't mind i have the following questions:
1. did you report this as a "bug" to Oracle ? is ESRI support investigated and reported this as a bug after checking your case ?
2. So, "extproc" configuration only worked when you reverted to 11.2.0.1 ?
irishadar
Emad Al-Mousa hi,
For you second question,  I don�??t know if it works only on 11.2.0.1 we never tested it again on 11.2.0.3 so if you follow the steps it might work for you.
I have to emphasis that our initial install process was not as described in my last replay, so we really don�??t know what made it work the oracle "reverted to 11.2.0.1" or simply the install process.
For the first question, we did open an incident in oracle, never got something worth working with, incident number: SR 3-6541500181 : extproc.ora DLL path not found
There was also incident opened at esri which resulted with the steps described in my last replay, Esri Incident #1105536.
And just to clarify we've got "extproc" and "tnsnames+listener" working side by side with no problem
Hope that helps you ,
Iris Hadar
EmadAl-Mousa
Thank You.
EmadAl-Mousa
after extensive troubleshooting, i found out that this will occur in one of two situations:
1. the libst_shapelib.so external procedure library is corrupted.
OR
2. the libst_shapelib.so external procedure library is a 32 bit.......to check that use the Unix Command ( file libst_shapelib.so
) the output should give you 64bit
in my situation, the library was corrupted (for some reason).....when i copied the the library form my local machine (
C:\Program Files (x86)\ArcGIS\Desktop10.1\DatabaseSupport)
to the database server and used the external procedure method 'ONLY' it worked fine and i was able to execute the query: select * from gdb_items_vw;
