FME errors
3445
05-30-2013 10:44 AM
clarenceburris
I'm using SchemaMapper in a dynamic ETL and am receiving the following errors associated with 2D features:
A 2D feature was encountered in the feature class 'sMeterPoint', which is defined as containing 3D features. The feature, and any other applicable features in the same feature class, will be modified so that it has the same dimension as the feature class
IFMEPoint was given a measure name that does not exist
A 2D feature was encountered in the feature class 'sUtilityArea', which is defined as containing 3D features. The feature, and any other applicable features in the same feature class, will be modified so that it has the same dimension as the feature class
IFMEArc was given a measure name that does not exist
Can someone explain what's happening?
BruceHarold
Esri Frequent Contributor
Hi Clarence
It means what it says, incoming 2D features will be made Z-aware, but it isn't clear what Z value will be assigned - maybe 0.
"Dimension" in this context means number of geometry dimensions - i.e. 3.
I'm not sure if the tool is seeing a route systems ("measures") on the data, if your features are M-aware you might want to drop the route system.
Regards
ThozamaDyonase
I want to greate a google earth overview using the spatial etl tool but i get the attached error message. Please Help.....
