SQL QUERY for data format
1558
07-24-2013 11:07 AM
benberman
I am trying to create an SQL expression that will test against the data formats that are in a particular field. All the entries in the field should of DATE format. Suggestions are welcome.
Thanks.
AnthonyGiles
Honored Contributor
If you are using a file geodatabase then use some thing like:
"Datefield" = date'2001-06-30 19:30:00'
For other databases the syntax maybe different check out this help page:
http://resources.arcgis.com/en/help/main/10.1/index.html#//00s500000033000000
Regards
Anthony
benberman
I am aware of how to test against a particular value. I will needing an SQL quert to test against Data FORMAT. Something to the likes of, "date_field" IS NOT FORMAT(DATE)
So far, have not found anything. Suggestions welcome.
AnthonyGiles
Honored Contributor
I'm not quite sure what you are trying to achieve the field type is set in the schema of the database. If a field is set to date then all values in that field have to be a date.
Regards
Anthony
VinceAngelo
Esri Esteemed Contributor
If you're looking for an RDBMS-specific solution to regular expression matching
in text fields to see if they conform to date formats, then the appropriate RDBMS
vendor's web site will likely be of most assistance.  I doubt File Geodatabases
support any such SQL function (in which case you'd need to walk the cursor
set on the table and use programming language functions on the text strings).
- V
