SQL geodatabase dbo.i tables?
2316
06-09-2022 02:16 PM
by Anonymous User
Not applicable
Hi all,
I'm looking in SQL Server Management Studio. I have a sql geodatabase that is esri version 10.9.1.2.9. I have researched and researched but I can't find the answer - does anyone know what these dbo.i__ tables are and what they are used for? Some kind of ID management.
Thank you,
Andrea
by Anonymous User
Not applicable
For anyone who is also curious my coworker was able to dig out these 2 links that help to explain it:
https://www.e-education.psu.edu/spatialdb/node/2036
https://gis.stackexchange.com/questions/266461/arcgis-sde-i5-i6-i7-tables
VinceAngelo
Esri Esteemed Contributor
SEQUENCEs are too slow for bulk-loading data rows. Esri uses "i-tables" to implement the equivalent in batches, with the name using the table_registry identifier as a suffix.  They used to be documented, but I can't find where it moved in the current doc set.
- V
by Anonymous User
Not applicable
