Splitting multiple lines at a specified distance
1009
12-14-2010 12:55 AM
OIKAGUDA
Hello!
What i got is a shapefile with thousands of roads which i want to split at a specified distance.
How can i manage that?
The split function in the editor toolbar can only split one road not more.
IanBroad2
I have this same question, using 10
How can I split MULTIPLE lines at a specified distance?
JonathanQuinn
Esri Notable Contributor
Do your lines need to be split at regular intervals?  For example, all of them need to be split in mile intervals?
JakubSisak
Honored Contributor
One workaround is to merge all lines into a single multi-geometry, then use the split tool as per usual.
