Split rectangular polygon into quadrants
2671
12-10-2013 06:07 AM
by Anonymous User
Not applicable
Original User: gizagui
Hi everybody,
I need to split one rectangular polygon into four equal quadrants.
The following images explain better the problem:
[ATTACH=CONFIG]29719[/ATTACH]
Figure 1: Before
[ATTACH=CONFIG]29720[/ATTACH]
Figure 2: After
Isn't a complicated problem, but is there any straight way to do this?
I'm working with ArcGIS 10.0 and ArcInfo license.
Thanks in advance.
DavidParker4
you can use the cut polygon tool and snap to midpoints going vertical and couple of points outside to get around to the end midpoint
and horizontal to the opposite midpoint & F2
dave
DavidParker4
dave
by Anonymous User
Not applicable
dave
Excellent! Dave, with your instructions I could do what I needed. Actually, it was not complicated ...
Thank you very much.
