Spatial Data Server / ORA-06512
695
07-19-2012 12:31 AM
Ganael_Jatteau
All,
I'am trying out the new component Spatial Data Server with an Oracle database that has a SDE server (which actually works fine with Arcgis Server and Desktop).
Deploying services (through Arcmap) on SDS works fine but I'm having difficulties to get the query operation to work on a REST layer.
I first had:
28595 : ORA-28595: Extproc agent : Invalid DLL Path ORA-06512: at "SDE.ST_GEOMETRY_SHAPELIB_PKG", line 216 ORA-06512: at "SDE.ST_GEOMETRY_OPERATORS", line 109
Which I solved following the doc at: http://resources.arcgis.com/en/help/main/10.1/index.html#//006z0000001w000000
And now the error has changed to look like:
28575 : ORA-28575: unable to open RPC connection to external procedure agent ORA-06512: at "SDE.ST_GEOMETRY_SHAPELIB_PKG", line 216 ORA-06512: at "SDE.ST_GEOMETRY_OPERATORS", line 109
It seems that SDS can go 1 step further but still has some issues with DLL.
When I run
select * from ALL_LIBRARIES  where library_name like 'ST_SHAPELIB'
it appears that shapelib is loaded with the correct path.
Any help appreciated! Thanks
ForrestJones
Hi Ganael,
One thing to check is if the oracle listener is started...
