I would create a new thread question in https://community.esri.com/groups/geodatabase?sr=search&searchId=051cc68d-7216-4718-a424-42a740fe3d25&searchIndex=0 space for this as this original thread is about 6 years old.
I would provide all the information related to client, geodatabase, RDBMS versions and how large is the feature class you are testing, what is the geometry being used, is the data versioned, etc.
Same Problem. And I did tests in PostGis with same table, here are my results:
ArcSDE: 25 seconds
Shapefile: 5 seconds
PostGIS: 5 seconds
File Geodatabase: 25 seconds
Seems like a "problem" with Geodabase.
How large is the shapefile (storage of .shp/.shx/.dbf combined)?How large is the table (incuding the related LOB table for SDO_GEOMETRY storage)?Databases have a *lot* more overhead to implement ACID (atomicity, consistency, isolation, durability) on each query, while a flat file has none. This is why flat files are very nearly always faster on a full table scan. Note that this is not an "ArcSDE performance" issue -- it's a *database* performance issue.If you want to improve database performance, you can follow this simple rule:Never draw all objects in large tablesThere are many ways to implement this: You can make the table thinner by generalizingthe geometries of objects with many vertices. You can make the table shorter by unioningrows by attribute. You can avoid querying the table by setting a scale dependency in theclient application. Or some combination of two or three.Since the data is basemap information you have additional options, including storing thedata in a different storage format, and using a map cache to avoid repeated rendering.- V
It would be very rare for a full table scan query in a database to outperform a local flat file. I've only seen that kind of performance from a DB2 database (which somehow returned 3.7Mpoint features [with ~1K of attributes] in under four seconds).It is impossible to control order of presentation out of databases without providing an explicitORDER BY clause. Generally, they will present the data in the order of the driving table orindex, but the optimizer and cache have free will without an ORDER BY (which usually slows down performance, since the data is copied to TEMP and sorted before return). Generally speaking, SDO_GEOMETRY will be slower than ST_GEOMETRY or SDELOB/SDEINARYon a full table scan query, simply because the Esri types use a compression algorithim that reduces storge significantly -- less data pages == faster transfer.Keep in mind that ArcSDE only returns the rows the database provides (in the order it provides them, subject to omission for failure to meet spatial filter criteria), so nothing in ArcSDE tuning can change SDO_GEOMETRY return order. You can only change return order of Esri storage types by specifying an SM_ENVP_BY_GRID search filter (and even that has not been reliable the last few releases). ArcSDE also has an optimizer that determines whether to query the table directly or use the spatial index (the threshold is based on comparison of the envelope of the search filter to the envelope of the layer, so changing the layer envelope can impact whether an explicit spatial constraint is applied [ArcSDE will filter geometries in the result stream either way]).I usually go out of my way to load data in an order which will permit the fastest possible spatial search performance, which involves exporting all rows in spatial index order and reloading themso that spatial fragmentation is kept to a minimum.- V
Which Oracle release are you using? (10.2.0.?) What geometry storage are you using?I was recently introduced to an optimizer issue that affects SDO_GEOMETRY inOracle 10.2.0.5-11.2.0.2. There are drastic and less drastic solutions avaliable.- V
