Simplest way to create a minimum bounding box for a tif image?
6030
12-10-2012 12:42 PM
GeorgeSinkinson
I would like to create a shapefile containing the bounding box for a tif raster file.
I'm new at this and am looking for the simplest, accurate way to do this.
I was given a NLCD file and want to draw a border around the entire image to define my area of interest.
I know I can draw a polygon by hand, but with all the available tools, I would think there was one to do this.
JoshuaDamron
I did a google search for "ArcGIS 10 create raster from polygon" and came upon this: http://help.arcgis.com/en/arcgisdesktop/10.0/help/index.html#//001200000008000000
I thin that's the tool you are looking for.  Post back if I missed your question...
Hope this helps!
JakeSkinner
Esri Esteemed Contributor
Hi George,
The Raster to Polygon tool will work as Joshua pointed out, but each cell will be converted to a polygon.  I would recommend using the Create Fishnet tool.  For the Template Extent parameter, specify the raster.  Then specify:
Cell Size Width:  0
Cell Size Height:  0
Number of Rows:  1
Number of Columns:  1
And POLYGON for the output type.
Also, if you have the 3D Analyst extension you could use the Raster Domain tool.
