File Geodatabase compression problem with linked anno's
1309
01-22-2013 10:51 AM
by Anonymous User
Not applicable
Original User: elangd
I am running into a problem when I export linked anno from SDE 10.1 Oracle to File Geodatabase.  It does not matter if I do feature class to feature class or export the anno's as linked anno's once I compress the File geodatabase that data crashes ArcMap 10.1.  I am sure ArcMap is crashing on drawing the anno layers.  Any suggestions, is this a known bug or does anybody not have the issue with linked annos and File geodatabase?????
Thanks in advance.
by Anonymous User
Not applicable
ESRI reports it is as a bug.  My work around is to compress the non annotation feature classes only.  I believe this is also an issue in 10.0.
"#NIM088887  ArcMap crashed when drawing feature linked annotation feature classes within a compressed file geodatabase"
