Show georeference information in attribute table
1167
09-27-2012 01:09 AM
JannWendt
maybe someone is able to help me or give me some hints.
Problem: I have a large dataset of images and some of them are georeferenced. Furthermore I have an shapefile containing the approximate extent of each image and some other attributes. Now I would like to include the information whether the image is georeferenced or not in the attribut table of the shapefile. Does someone has an idea how to do it automatically?
Best regards!
JeffreySwain
Perhaps the Get Raster Properties tool will be of use.  If your data is unprojected the spatial extents will not be in the correct coordinate system.  Sometimes these values will start at 0.  So perhaps you could populate a field with the values obtained when looking at the Top or Left option.
