Shapefile feature count vs. database count problem
1314
08-17-2017 02:10 PM
JohnnyJohansson
I have gotten an shapefile witch I want to open in an other program, but there seams to be an misscount of features in the shp file and the db file, how to i fix this?
MicahBabinski
Your shapefile looks fine. What's the error you are seeing?
shan_sarkar
Jhonny,
Was the shapefile created using ArcGIS Desktop?
What application are you trying to open it?
Can you share the error message it throws while opening it in the other application?
~Shan
~Shan
DanPatterson_Retired
Run a check geometry ... followed by a repair geometry if errors were found (ie null shapes)
