Select a point by attribute inside a polygon
2758
07-16-2021 09:50 AM
ManfredSaberbein
Hi, I have 88k polygons with 128k points and I want to select the points with the highest attribute "1-12" inside each polygon.
Thank you
ThomasHamill
@ManfredSaberbein you could also do this with a Spatial Join.  Spatially Join the Points layer to the Polygons layer and select the option that would "Summarize by Maximum."
If you run the Intersect tool instead, I'd recommend running Table To Excel afterwards and pull the data into a Pivot Table for easy summarization (to find the max of the Point field of interest).
Kindest Regards,
t
RPGIS
by MVP Regular Contributor
So you can accomplish this using the intersect tool (or similar) in conjunction with other tools, or methods, to determine the highest "1-12" for each polygon assuming that each polygon has that many points inside.
Also, what do you mean by highest attribute "1-12". If you mean ObjectID, then that will take a few more steps.
ThomasHamill
Kindest Regards,
t
ManfredSaberbein
Thank you, I did it! 🎉
