SDE 9.3.1 Compress Error
1802
07-12-2012 10:00 AM
brianscholl
We are getting an error during compression:
ERROR 999999: Error executing function.
Underlying DBMS error [ORA-29861: domain index is marked LOADING/FAILED/UNUSABLE
] [SDE.DEFAULT]
Failed to execute (Compress).
Any Ideas?
VinceAngelo
Esri Esteemed Contributor
What version of Oracle are you using?
What geometry storage type are you using?
Are you using partitioning?
- V
brianscholl
Oracle 11.2.0.3  Windows 2008R2 64-bit
SDO Geometry.
No Partitioning.
VinceAngelo
Google on the ORA-29861 error.  It's been too long to remember the details, but the
SDO_GEOMETRY index can get in a strange state where the index is corrupt, so you
can't rebuild it and you can't drop it either.  There's a workaround where you hack
the index metadata table, then drop the index; from there you can rebuild it.
- V
