Script to find 'move edits to base' setting
1329
11-25-2021 05:05 AM
Labels (3)
ÅsaBlomberg
We have many hundred feature classes and we discovered that some of them by mistake have the versioning setting 'move edits to base'.
Is there a way to find out which feature classes that have this setting? Maybe with SQL or python?
Microsoft SQL Server, ArcGIS Enterprise 10.8
by Anonymous User
Not applicable
Hello AsaBlomberg,
The best I was able to find was to use arcpy.Describe() function to return a True/False if the data is versioned or not. Unfortunately, this only returned True regardless of the versioned status (with or without the "Move-edits-to-base" option checked). See screenshot from Python window in ArcGIS Pro:
Here is the documentation for the Describe function: Describe function documentation. You could try looking through all the options to see if one would determine True/False for the "Move-edits-to-base" check box.
Cheers,
Mike
