Retrieving a feature class which was deleted from child version.
3256
11
10-12-2012 09:33 AM
Sandyd
We have a Default version and a child version. One of my colleague had deleted a feature class from Child version. Is it possible to retrieve the deleted feature class to the child version.
Sandy.
AsrujitSengupta
Versions are database specific and not data specific.
In your case it might be that, the user using the Child Version doesn't have enough privileges to view that Feature Class
Sandyd
Rujit,
Thanks for the reply. I have a question..In our case the feature class was deleted from child version. Will that deleted feature class be available in default version.
Sandy.
JoeBorgione
I'm confused with your terminology: Typically DEFAULT refers to a versioned database.  All versions are contained within the same data base.  All subsequent versions have a relationship back to default.  If you choose to reconcile and post any changes made to a specific version, you do so with respect to the version from which it was spawned.
Typically, CHILD refers to a replicated database.  Replication is between TWO separate databases. The relationship between a child and its parent can be one or two way.  In a one way replication scenario, changes can only go one way: from either parent to child or child to parent.  In a two way scenario, changes made to the parent can be syncronized to the child and/or changes to the child can be syncronized to the parent.
If you delete a version, default is secure.  If you delete a child, the parent is secure.  You stand to lose an changes however that were not reconciled and posted or syncronized respectively.
That should just about do it....
AsrujitSengupta
Sandy,
Just like Joe mentioned.....the terminologies that you are using are confusing.
If you are talking about SDE.Default version and a child version of the default, in a geodatabase....then NO....the data will not be present in the geodatabase.
The confusing bit is......If you are connected to the geodatabase through a CHILD version, and delete the data.....then the data gets deleted from your geodatabase, and not just from that version!!  In this case you won't be able to see the data in the geodatabase even if you connect using the SDE.Default version.
If you are talking about PARENT & Child Replica, which involves two different geodatabases.....then the answer is YES ....if the data has been deleted in the Child Geodatabse...the data will still be present in the Parent Geodatabase....
Regards,
Asrujit
JoeBorgione
Having a regular back up schedule is an essential element of any enterprise database system....
Sandyd
Okay. Which is the best backup policy for enterprise database system ? Cold, Hot or RMAN ?
JoeBorgione
Not sure what you mean by hot or cold;  I have a SQL Server back end and run a back up there nightly.
AsrujitSengupta
Sandy,
I would say "Cold Backup" is the safest way to back up because it avoids the risk of copying data that may be in the process of being updated. However, a cold backup involves downtime because users cannot use the database while it is being backed up, so it basically depends on your workflow.
As you mentioned RMAN, I'm guessing that you are using Oracle DBMS. I can't really say about the RMAN much as I'm not familiar with it, as much as the other two. But as far as I understand RMAN uses the same HOT(online) & COLD(offline) backup methods.
So go for RMAN Offline Backup..;)
Regards
LeoDonahue
If you have a Parent version and Child version and a feature was deleted in the Child version, whether it is lost depends on whether it was a new feature that was added using the Child version or whether it was an existing feature in the Parent version, right?  If it was an existing feature, then it should still be in the parent version, and when you reconcile/post, can't you manually review that edit and favor the Parent version?
As for backups, we have a nightly backup in SQL Server.  But that means I'm willing to lose a day's worth of edits.
We set default to protected and make our child versions public.  But that also means that we have to pay attention to what we are reconciling and posting to default.
If you have already reconciled and posted the deleted feature in the child version to the parent version (sde.default), you're done, it's gone.  Unless you haven't synchronized changes in your replica, then that feature would still be in your replicated geodatabase (hopefully).
