Remove noise Grid
3330
09-29-2012 04:15 AM
ludovicofrate
Hi there!
In ArcView exists a function in the generalize grid tool, that allows to remove noise (is called just like that) in a grid image. Can ArcGis 10 perform the same operation?
Thanks
JeffreySwain
There are several options in the Generalization Tools for Spatial Analyst.  Depending on what type of generalization that you are looking to perform you may prefer the Majority Filter or perhaps Nibble.
ludovicofrate
thank you for the answer! But I need to remove pixel under a threshold (10 pixel) and both Majority filter and Nibble do not allow to do this!
JeffreyEvans
The Sieve tool in our Geomorphometry and Gradient Metrics Toolbox will do exactly what you are wanting.
http://conserveonline.org/workspaces/emt/documents/all.html
ludovicofrate
Thank you for the tip! I still haven't tried the tool but i have found this procedure
http://resources.arcgis.com/en/help/main/10.1/index.html#//00nv00000010000000
