Reindex GDB Tables
5080
7
03-14-2024 05:08 AM
CodyPatterson
MVP Regular Contributor
Hey All,
Enterprise 11.2 Geodatabase.
I have been reindexing our Enterprise Geodatabase every day, as we write quite often to this DB, and have noticed using a fragmentation query, that we have a few tables that don't seem to reindex, these include GDB_ITEMS and SDE_column_registry. These are unable to be selected via ArcGIS Pro, so I was curious if these should be reindexed, or if these should just be disregarded, they are quite large.
Thanks in advance!
Cody
2 Solutions
KimberleeHermann1
Hello...if you are using SQL Server it is super easy to use the Maintenance Plan wizard and do a reindex of everything on a database. Usually doesn't take long at all. I have it scheduled for all of my databases each weekend and that seems to keep thing "all good".
MarceloMarques
@CodyPatterson - I usually avoid using the ArcGIS Pro GP Tools to gather new statistics and to rebuild indexes (attribute indexes and spatial indexes ) in my production geodatabases because these tools to not offer advanced options that you find with the SQL Server SQL Commands to do the same. I suggest you use the SQL Server Tools to do this maintenance.
You can find my maintenance scripts for SQL Server in my community.esri.com blog below, download the database template scripts for SQL Server.
Mapping and Charting Solutions (MCS) Enterprise Da... - Esri Community
Your question about the GDB_ITEMS table and any other ArcSDE Repository Tables. Yes, those tables must be reindexed as well, probably not every day, as you will not be creating new featureclasses, etc. in the geodatabase, but you should reorganize indexes weekly and rebuild indexes monthly at least for the ArcSDE Repository Tables, and right after that gather new statistics.
For reference to others about this discussion follow below the links for the ArcGIS Pro GP Tools.
Enterprise geodatabase maintenance tasks—ArcGIS Pro | Documentation
Modify a spatial index—ArcGIS Pro | Documentation
Rebuild Indexes (Data Management)—ArcGIS Pro | Documentation
Update database statistics—ArcGIS Pro | Documentation
I hope this helps.
| Marcelo Marques | Esri Principal Product Engineer | Cloud & Database Administrator | OCP - Oracle Database Certified Professional | "About: In 1992, I embarked on my journey with Esri Technology, and since 1997, I have been working with ArcSDE Geodatabases, right from its initial release. Over the past 33 years, my passion for Spatial Databases and GIS data has become a central part of my career.." | “ The mountains are calling and I must go.” – John Muir |
KimberleeHermann1
CodyPatterson
Hey @KimberleeHermann1
Thank you for that tip, I was not sure if the SQL way would be preferable, or the ArcGIS Pro way, but it seems that the SQL way is more preferred! I will give that a shot and go through with it that way, my initial assumption was that since they are ArcGIS Pro provided indexes through GDB functionality, then they could only be rebuilt within Pro, but we learn as we go!
Cody
MarceloMarques
I hope this helps.
CodyPatterson
Hey @MarceloMarques
Thank you for the tip! I will check that out to see what I can manage with that! I spoke with another commenter and said that I was not confident on which method to use, since my assumption was that since it's a Pro index, I must do it in Pro, but it looks like that's incorrect.
I appreciate the documentation too!
Cody
ModyBuchbinder
Hello all
I am running in similar program.
I use Maintenance Plan to check and index my tables.
When it try to reindex GDB_ITEMS I get this error:
ALTER INDEX [R6_pk] ON [sde].[GDB_ITEMS] REORGANIZ..." failed with the following error: "The index "R6_pk" on table "GDB_ITEMS" cannot be reorganized because
page level locking is disabled."
We did not changed anything in the system tables.
Any idea?
MarceloMarques
This is well known, and the change to the indexes was implemented many releases ago when Geodatabase Branch Versioning was introduced. Refer to my earlier reply above for links to my database maintenance scripts.
Examples:
- execute every month - rebuild indexes
CREATE PROCEDURE [dbo].[mp_rebuild_indexes_gisgdb]
  @fillfactor INT = 75
AS
BEGIN
    DECLARE @DbId VARCHAR(255)
	DECLARE @Database VARCHAR(255)
	DECLARE @SchemaName VARCHAR(256)
    DECLARE @TableName VARCHAR(256)
    DECLARE @IndexName VARCHAR(256)
	DECLARE @cmd NVARCHAR(500)
	--DECLARE @fillfactor INT = 75
	DECLARE DatabaseCursor CURSOR LOCAL FORWARD_ONLY STATIC READ_ONLY FOR
	SELECT dbid, name FROM master.dbo.sysdatabases
	WHERE name NOT IN ('master','msdb','tempdb','model')
	AND name = 'gisgdb'
	ORDER BY 1
	OPEN DatabaseCursor
	FETCH NEXT FROM DatabaseCursor INTO @DbId,@Database
	WHILE @@FETCH_STATUS = 0
	BEGIN
	  PRINT ('DB: '+ @Database)
	  SET @cmd = 'USE ' + @Database + ';'
	  PRINT (@cmd)
	  EXEC (@cmd)
	  PRINT ('Indexes allow_page_locks = 1')
	  --Indexes allow_page_locks = 1
      SET @cmd = 'DECLARE IndexCursor CURSOR FOR SELECT OBJECT_SCHEMA_NAME(t.object_id,' + @DbId +') schema_name, t.name table_name,  i.name index_name
	  FROM ' + @Database + '.sys.indexes i
      INNER JOIN ' + @Database + '.sys.tables t ON t.object_id= i.object_id
      WHERE i.allow_page_locks = 1 AND t.Name IS NOT NULL AND i.name IS NOT NULL'
	  -- create index cursor
	   PRINT (@cmd)
	   EXEC (@cmd)
	   OPEN IndexCursor
	   FETCH NEXT FROM IndexCursor INTO @SchemaName,@TableName,@IndexName
	   BEGIN
           PRINT ('Index_Name: ' + @Database + '.' + @SchemaName + '.' + @TableName + '.' + @IndexName)
		   BEGIN TRY
			   --SET @cmd = 'ALTER INDEX ' + @IndexName + ' ON ' + @Database + '.' + @SchemaName + '.' + @TableName + ' REBUILD WITH (FILLFACTOR = ' + CONVERT(VARCHAR(3),@fillfactor) + ')'
			   SET @cmd = 'ALTER INDEX ' + @IndexName + ' ON ' + @Database + '.' + @SchemaName + '.' + @TableName + ' REBUILD;'
			   PRINT @cmd
			   EXEC (@cmd)
		   END TRY
		   BEGIN CATCH
			   PRINT 'This is the error: ' + error_message()
		   END CATCH
	   END
	   CLOSE IndexCursor
	   DEALLOCATE IndexCursor
      PRINT ('Indexes allow_page_locks = 0')
	  --Indexes allow_page_locks = 0
      SET @cmd = 'DECLARE IndexCursor CURSOR FOR SELECT OBJECT_SCHEMA_NAME(t.object_id,' + @DbId + ') schema_name, t.name table_name,  i.name index_name
      WHERE i.allow_page_locks = 0 AND t.Name IS NOT NULL AND i.name IS NOT NULL'
	   PRINT (@cmd)
	   EXEC (@cmd)
	   OPEN IndexCursor
	   BEGIN
		   BEGIN TRY
			   SET @cmd = 'ALTER INDEX ' + @IndexName + ' ON ' + @Database + '.' + @SchemaName + '.' + @TableName + ' SET (ALLOW_PAGE_LOCKS = ON);'
			   PRINT @cmd
			   EXEC (@cmd)
			   PRINT @cmd
			   EXEC (@cmd)
			   SET @cmd = 'ALTER INDEX ' + @IndexName + ' ON ' + @Database + '.' + @SchemaName + '.' + @TableName + ' SET (ALLOW_PAGE_LOCKS = OFF);'
			   PRINT @cmd
			   EXEC (@cmd)
		   END TRY
		   BEGIN CATCH
		   END CATCH
	   END
	   CLOSE IndexCursor
	END
	CLOSE DatabaseCursor
	DEALLOCATE DatabaseCursor
END
GO
- execute every week - reorganize indexes
CREATE PROCEDURE [dbo].[mp_reorganize_indexes]
AS
BEGIN
	--AND name = 'topo2'
	ORDER BY 1
	OPEN DatabaseCursor
	BEGIN
	  PRINT (@cmd)
	  EXEC (@cmd)
	   PRINT (@cmd)
	   EXEC (@cmd)
	   OPEN IndexCursor
	   BEGIN
		   BEGIN TRY
			   SET @cmd = 'ALTER INDEX ' + @IndexName + ' ON ' + @Database + '.' + @SchemaName + '.' + @TableName + ' REORGANIZE  WITH ( LOB_COMPACTION = ON );'
			   PRINT @cmd
			   EXEC (@cmd)
		   END TRY
		   BEGIN CATCH
		   END CATCH
	   END
	   CLOSE IndexCursor
	   PRINT (@cmd)
	   EXEC (@cmd)
	   OPEN IndexCursor
	   BEGIN
		   BEGIN TRY
			   PRINT @cmd
			   EXEC (@cmd)
			   PRINT @cmd
			   EXEC (@cmd)
			   PRINT @cmd
			   EXEC (@cmd)
		   END TRY
		   BEGIN CATCH
		   END CATCH
	   END
	   CLOSE IndexCursor
	END
END
GO
KimberleeHermann1
You are very welcome!! So glad it worked for you.
