Hey All,
Enterprise 11.2 Geodatabase.
I have been reindexing our Enterprise Geodatabase every day, as we write quite often to this DB, and have noticed using a fragmentation query, that we have a few tables that don't seem to reindex, these include GDB_ITEMS and SDE_column_registry. These are unable to be selected via ArcGIS Pro, so I was curious if these should be reindexed, or if these should just be disregarded, they are quite large.
Thanks in advance!
Cody
@CodyPatterson - I usually avoid using the ArcGIS Pro GP Tools to gather new statistics and to rebuild indexes (attribute indexes and spatial indexes ) in my production geodatabases because these tools to not offer advanced options that you find with the SQL Server SQL Commands to do the same. I suggest you use the SQL Server Tools to do this maintenance.
You can find my maintenance scripts for SQL Server in my community.esri.com blog below, download the database template scripts for SQL Server.
Mapping and Charting Solutions (MCS) Enterprise Da... - Esri Community
Your question about the GDB_ITEMS table and any other ArcSDE Repository Tables. Yes, those tables must be reindexed as well, probably not every day, as you will not be creating new featureclasses, etc. in the geodatabase, but you should reorganize indexes weekly and rebuild indexes monthly at least for the ArcSDE Repository Tables, and right after that gather new statistics.
For reference to others about this discussion follow below the links for the ArcGIS Pro GP Tools.
Enterprise geodatabase maintenance tasks—ArcGIS Pro | Documentation
Modify a spatial index—ArcGIS Pro | Documentation
Rebuild Indexes (Data Management)—ArcGIS Pro | Documentation
Update database statistics—ArcGIS Pro | Documentation
I hope this helps.
Thank you for that tip, I was not sure if the SQL way would be preferable, or the ArcGIS Pro way, but it seems that the SQL way is more preferred! I will give that a shot and go through with it that way, my initial assumption was that since they are ArcGIS Pro provided indexes through GDB functionality, then they could only be rebuilt within Pro, but we learn as we go!
Cody
I hope this helps.
Hey @MarceloMarques
Thank you for the tip! I will check that out to see what I can manage with that! I spoke with another commenter and said that I was not confident on which method to use, since my assumption was that since it's a Pro index, I must do it in Pro, but it looks like that's incorrect.
I appreciate the documentation too!
Cody
Hello all
I am running in similar program.
I use Maintenance Plan to check and index my tables.
When it try to reindex GDB_ITEMS I get this error:
ALTER INDEX [R6_pk] ON [sde].[GDB_ITEMS] REORGANIZ..." failed with the following error: "The index "R6_pk" on table "GDB_ITEMS" cannot be reorganized because
page level locking is disabled."
We did not changed anything in the system tables.
Any idea?
This is well known, and the change to the indexes was implemented many releases ago when Geodatabase Branch Versioning was introduced. Refer to my earlier reply above for links to my database maintenance scripts.
Examples:
- execute every month - rebuild indexes
CREATE PROCEDURE [dbo].[mp_rebuild_indexes_gisgdb]
@fillfactor INT = 75
AS
BEGIN
DECLARE @DbId VARCHAR(255)
DECLARE @Database VARCHAR(255)
DECLARE @SchemaName VARCHAR(256)
DECLARE @TableName VARCHAR(256)
DECLARE @IndexName VARCHAR(256)
DECLARE @cmd NVARCHAR(500)
--DECLARE @fillfactor INT = 75
DECLARE DatabaseCursor CURSOR LOCAL FORWARD_ONLY STATIC READ_ONLY FOR
SELECT dbid, name FROM master.dbo.sysdatabases
WHERE name NOT IN ('master','msdb','tempdb','model')
AND name = 'gisgdb'
ORDER BY 1
OPEN DatabaseCursor
FETCH NEXT FROM DatabaseCursor INTO @DbId,@Database
WHILE @@FETCH_STATUS = 0
BEGIN
PRINT ('DB: '+ @Database)
SET @cmd = 'USE ' + @Database + ';'
PRINT (@cmd)
EXEC (@cmd)
PRINT ('Indexes allow_page_locks = 1')
--Indexes allow_page_locks = 1
SET @cmd = 'DECLARE IndexCursor CURSOR FOR SELECT OBJECT_SCHEMA_NAME(t.object_id,' + @DbId +') schema_name, t.name table_name, i.name index_name
FROM ' + @Database + '.sys.indexes i
INNER JOIN ' + @Database + '.sys.tables t ON t.object_id= i.object_id
WHERE i.allow_page_locks = 1 AND t.Name IS NOT NULL AND i.name IS NOT NULL'
-- create index cursor
PRINT (@cmd)
EXEC (@cmd)
OPEN IndexCursor
FETCH NEXT FROM IndexCursor INTO @SchemaName,@TableName,@IndexName
BEGIN
PRINT ('Index_Name: ' + @Database + '.' + @SchemaName + '.' + @TableName + '.' + @IndexName)
BEGIN TRY
--SET @cmd = 'ALTER INDEX ' + @IndexName + ' ON ' + @Database + '.' + @SchemaName + '.' + @TableName + ' REBUILD WITH (FILLFACTOR = ' + CONVERT(VARCHAR(3),@fillfactor) + ')'
SET @cmd = 'ALTER INDEX ' + @IndexName + ' ON ' + @Database + '.' + @SchemaName + '.' + @TableName + ' REBUILD;'
PRINT @cmd
EXEC (@cmd)
END TRY
BEGIN CATCH
PRINT 'This is the error: ' + error_message()
END CATCH
END
CLOSE IndexCursor
DEALLOCATE IndexCursor
PRINT ('Indexes allow_page_locks = 0')
--Indexes allow_page_locks = 0
SET @cmd = 'DECLARE IndexCursor CURSOR FOR SELECT OBJECT_SCHEMA_NAME(t.object_id,' + @DbId + ') schema_name, t.name table_name, i.name index_name
WHERE i.allow_page_locks = 0 AND t.Name IS NOT NULL AND i.name IS NOT NULL'
PRINT (@cmd)
EXEC (@cmd)
OPEN IndexCursor
BEGIN
BEGIN TRY
SET @cmd = 'ALTER INDEX ' + @IndexName + ' ON ' + @Database + '.' + @SchemaName + '.' + @TableName + ' SET (ALLOW_PAGE_LOCKS = ON);'
PRINT @cmd
EXEC (@cmd)
PRINT @cmd
EXEC (@cmd)
SET @cmd = 'ALTER INDEX ' + @IndexName + ' ON ' + @Database + '.' + @SchemaName + '.' + @TableName + ' SET (ALLOW_PAGE_LOCKS = OFF);'
PRINT @cmd
EXEC (@cmd)
END TRY
BEGIN CATCH
END CATCH
END
CLOSE IndexCursor
END
CLOSE DatabaseCursor
DEALLOCATE DatabaseCursor
END
GO
- execute every week - reorganize indexes
CREATE PROCEDURE [dbo].[mp_reorganize_indexes]
AS
BEGIN
--AND name = 'topo2'
ORDER BY 1
OPEN DatabaseCursor
BEGIN
PRINT (@cmd)
EXEC (@cmd)
PRINT (@cmd)
EXEC (@cmd)
OPEN IndexCursor
BEGIN
BEGIN TRY
SET @cmd = 'ALTER INDEX ' + @IndexName + ' ON ' + @Database + '.' + @SchemaName + '.' + @TableName + ' REORGANIZE WITH ( LOB_COMPACTION = ON );'
PRINT @cmd
EXEC (@cmd)
END TRY
BEGIN CATCH
END CATCH
END
CLOSE IndexCursor
PRINT (@cmd)
EXEC (@cmd)
OPEN IndexCursor
BEGIN
BEGIN TRY
PRINT @cmd
EXEC (@cmd)
PRINT @cmd
EXEC (@cmd)
PRINT @cmd
EXEC (@cmd)
END TRY
BEGIN CATCH
END CATCH
END
CLOSE IndexCursor
END
END
GO
You are very welcome!! So glad it worked for you.
