Register versioned geodatabase using ArcGIS Server Manager
1425
07-09-2014 04:27 AM
El_BoukfaouiReda
Dear,
I am tryingto register a versioned geodatabase using ArcGIS Server Manager and I am facing the problem shown in the image herewith attached:
I am receiving this message on which I have no clue !
Am I missing something here?
Please help !
Technical Specs.
- OS : Windows Server 2012.
- ArcGIS Server 10.1 SP1 (Advanced)
- MS SQL Server 2008 R2 Native Client (10.50.1600.1)
- MS SQL Server 2012 Native Client. (11.1.3000.0) (Installed by default in the machine)
George_Thompson
Esri Notable Contributor
Was there an error message given in the red bubble? It will be very difficult to troubleshoot with no error message.
Have you tried to re-install the SQL Server Native client on the ArcGIS Server machine, I would make sure to use the 64-bit 2012 native client?
Also make sure that the ArcGIS Server machine has access to the SQL Server database instance.
http://resources.arcgis.com/en/help/main/10.1/index.html#/Registering_your_data_with_ArcGIS_Server_u...
-George
--- George T.
AsrujitSengupta
Also, try registering the database with ArcGIS Server from ArcCatalog and check if you observe the same issue there.
DivyamGulati
Any specific error in AGS logs? Logs may provide some help in debugging the problem.
