Re: Spatial Database Connection with ArcCatalog
3705
12
05-31-2013 05:43 AM
VinceAngelo
Esri Esteemed Contributor
*All* of the elements in that software stack were retired last decade:
  • ArcSDE 8.1 (2004)
  • Oracle 8i (2006)
  • Solaris 2.8 (2007)
  • ArcGIS Desktop 8.3 (2008)
  • Windows 2000 (2010)
It seems a bit late to be attemping initial install now.  I doubt it's even
possible to generate a keycode for any of the Esri stuff anymore.
- V
MarcoBoeringa
Thanks Vince.
I am able to make the connection now 🙂
Good to hear you got it running.
Would welcome the any steps & tips on this 🙂
There was a nice extension for extracting much of the Geodatabase's schema details in the times of 8.x and 9.x:
The Geodatabase Reporter by Richie Carmichael of ESRI:
http://arcscripts.esri.com/details.asp?dbid=13508
It created very nice HTML reports showing detailed info about Feature Datasets, Feature Classes, Relationships Classes, Domains etc, even including user info if I remember well.
Since you're running legacy 8.x, you might try and install it and see if you can get it working. Should be of real help in getting a good overview of the Geodatabase's schema.
Marco,
Thanks for the comments. But let's not discuss the sensitive data/policies of company. May be my mistake of publishing non-required things here.
Sorry, just couldn't help notice it and it made me smile... I know I can be a bit direct in these issues.
Good luck with the project and migration!
SandipSawant
Thanks a lot Marco & Vince.
Finally along with the spatial database connection, I could generate the Metadata (Geodatabase schema details, object class, etc.) report using Geodatabase Reporter extension as well.
It will really help us in next migration.
Warm regards,
Sandip
SandipSawant
Thanks again
