Composite Bands tool writing BIL file when BSQ specified
854
08-23-2013 06:41 AM
SimonMitchell1
Hi all,
I am having some weird problem with the Composite Bands Tool.
When I run the Composite Bands Tool and specify the output to be .bsq, the output will be a .bil file
So I run the command
"CompositeBands_management Red_Template;NIR_Template;Band_Template_MIR;Band_Template_TIR D:\Simon_M\Simulation\Area_Simulation\Comp_Bands_2.bsq"
And the output header given is
BYTEORDER      I
LAYOUT         BIL
NROWS          3072
NCOLS          3072
NBANDS         4
NBITS          8
BANDROWBYTES   3072
TOTALROWBYTES  12288
PIXELTYPE      UNSIGNEDINT
ULXMAP         0.5
ULYMAP         3071.5
XDIM           1
YDIM           1
NODATA         0
Also, the above input rasters are Integer format, but when I run the same Tool with rasters in Float format, I get the following error
ERROR 999999: Error executing function.
Failed to copy raster dataset
Failed to execute (CompositeBands).
If someone can shed some light on this, it will be much appreciated.
Many thanks
Simon
