Rasters comparison after load
5290
10
10-28-2015 01:05 PM
Ulises
Maybe this one is an easy fix, but I just can't see the difference.
I have a raster dataset in a file geodatabase that looks smooth and good at all scales.  I imported it to SDE geodatabase and set the same parameters for compression and pyramids (which I build after the import operation), but the raster looks very coarsely compared at small scales.  Calculated statistics trying, but the results do not vary.  Any suggestions are appreciated.
Ulises Feliciano Troche
Tags (3)
Ulises
Same thing...Diego is asking for the same issue.
Thanks for the info, Dan.
