Raster Data only displays when zoomed in beyond 1:1000
2592
01-07-2014 05:46 AM
JakeGalyon
I successfully imported a raster dataset into a file geodatabase.  When i load the raster into arcmap, it doesn't seem visible.  However, when i zoom in beyond 1:1000 the raster displays.  This was a Mr Sid that was directly imported into a file gdb with a .5 cell size.  Any thoughts on how i would get that to display at all scales?  Any help will be appreciated!
JakeSkinner
Esri Esteemed Contributor
Hi  Jake,
Try building pyramids on the raster dataset (right-click on the raster in the Catalog window > Build Pyramids).
JakeSkinner
Hi  Jake,
JakeGalyon
That worked.  Thanks!
KateDoughty1
For other users, I just wanted to note that this did not work for me when rasters are stored in a file geodatabase; works if stored in folder. Not sure what the workaround it for geodatabase rasters.
