"Windows Installer" attempting to install AutoCAD Map
1265
11-17-2010 09:03 AM
RayThompson
I am running AutoCAD Map 3D 2010 and ArcGIS 9.3.1.
When I start Arc, I get the following error box:
AutoCAD Map 3D 2010
"Please wait while Windows configures AutoCAD Map 3D 2010."
Then I need to hit cancel about three times before it will finally give up and let me into Arc. Any suggestions would be much appreciated.
Ray
MarkusRösgen
Hi Ray
We had the same problem. The solution is simple, try the following:
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=14174241&linkID=9240857
Cheers,
Markus
RonaldBingham
Thank you I also had the same problem.
