QuickExport Fails
1460
10-25-2010 01:59 PM
ClaudeKershaw
ArcEngine 10
License control correctly set
the following code fails to execute, please help 🙂
            Geoprocessor gp = new Geoprocessor();
            QuickExport qe = new QuickExport();
            qe.Input = "C:\\temp\\qe\\Line_88.shp";
            qe.Output = "GML, C:\\temp\\qe\\Line_88.gml";
            gp.OverwriteOutput = true;
            gp.Execute(qe, null); // this line fails : Error HRESULT E_FAIL has been returned from a call to a COM component
JeffReinhart
Your issues appears to be not checking out the extension in your script. I have attached a link to AOInitialize for license Extension codes.
http://help.arcgis.com/en/sdk/10.0/v...0000021000000/
Jeff
ClaudeKershaw
Hi Jeff,
the link returns The webpage cannot be found error 😞
I agree, licenseStatus returns ESRIlicenseNotLicensed, do I need the extension licensed on my development machine? According to ArcGIS Manager Data Interoperability is installed and authorized for Engine.
IAoInitialize aoInitialize = new ESRI.ArcGIS.esriSystem.AoInitializeClass();
            esriLicenseStatus licenseStatus = aoInitialize.IsExtensionCodeAvailable(esriLicenseProductCode.esriLicenseProductCodeArcView, esriLicenseExtensionCode.esriLicenseExtensionCodeDataInteroperability);
            MessageBox.Show(licenseStatus.ToString());
            MessageBox.Show(aoInitialize.IsExtensionCheckedOut(esriLicenseExtensionCode.esriLicenseExtensionCodeDataInteroperability).ToString());
            aoInitialize.CheckOutExtension(esriLicenseExtensionCode.esriLicenseExtensionCodeDataInteroperability);
            aoInitialize.CheckInExtension(esriLicenseExtensionCode.esriLicenseExtensionCodeDataInteroperability);
PrateekBansal
Hi just wondering if you were able to resolve to it as i am facing the same problem only that
esriLicenseStatus licenseStatus = aoInitialize.IsExtensionCodeAvailable(esriLicenseP roductCode.esriLicenseProductCodeArcView, esriLicenseExtensionCode.esriLicenseExtensionCodeD ataInteroperability);
this shows me true .
Would appreciate your help as I am stuck .
AnantThunuguntla
I created a new Console Application(Engine) in Visual Studio 2008. I then selected the License Checking options as shown in screenshot and added the desired References
Then ran the below code:
                qe.Input = "C:\\ Streets.shp";
                qe.Output = "GML, C:\\test.gml";
It gave me no errors. However, when I replaced it with the LicenseInitializer code you posted it did not work. Try the above method and if it fails please contact Tech Support. This was tested on ArcGIS 10 SP1.
