QueryDef problem
1784
02-26-2013 05:56 AM
pabloberlanga_jimenez
Hi!
I'd like to code a "self join query" with IQueryDef.
I'm using 9.3 sp2.
The SQL query is somethig like this:
SELECT ID
FROM MY_TABLE a, MY_TABLE b
WHERE a.id = b.id
AND a.date_1 = b.date_2
I have problems to do it since I cannot use alias in QueryDef.
Any ideas? Thank you in advance!
VinceAngelo
Esri Esteemed Contributor
You can accomplish this with Query Layers (at 10.x), but the query itself doesn't really make sense --
it's logically equivalent to "WHERE date_1 = date_2".
- V
BTW: The last 9.3 service pack was SP1 (followed by 9.3.1, which had two SPs).
It is 9.3.1 you're right.
But I think the query has logic:
SELECT id
FROM table a, table b
WHERE a.id = b.id
AND a.start_date = b.end_date
id       |      start_date      |   end_date   | more data....
181    |      01/02/2012    |   30/02/2012  | ...
181    |      01/01/2012    |   01/02/2012  |  ...
I would get this 181.
Thanks for you attention!!! 🙂
SELECT id
WHERE a.id = b.id
If I launch the query in SQL Server I get the waited results But If I construct the QueryDef and I evaluate it, it returns Nothing.
VinceAngelo
The ArcObjects forum is a better place to discuss this, but I doubt you're using the
correct object to accomplish a self-join.
- V
Ok. I move the question to the correct place.
Thank you again.
