Cannot right click in an edit session with PerfQA Analyzer installed
2068
07-04-2012 06:02 AM
TimLangner
Hi there
The other day I installed PerfQA_Analyzer for ArcGIS Desktop 10. I am running Editor version 10.0.4 of ArcMap. Everything was fine until today.
When I start an edit session and right click on a feature to use additional options, no menu is coming up. This was only resolved by the uninstalling of the above program. I can right click on menus and other parts of the screen but not the map part. Whether it affects other functions beyond just editing I don't know but if so it appears to be anything in the map window.
Has anyone else come across this or know why it would occur? I've not actually used PerfAQ Analyzer yet. Therefore I don't fully understand how it works and how to use it. Would I have done something in the program to cause this behaviour?
Kind regards
Tim
RobMower
I know it's almost a year late, but I have found the same thing. I'm currently running 10 SP2 and I had also lost the ability to get any of the right-click menus to load.
I had even recreated my normal template from scratch, which seemed to work until I added all the toolbars again. Your thread prompted me to look at PerfQAAnalyzer. Sure enough, once I had removed the toolbar and restarted ArcMap, my right click worked again!
This isn't really a solution, but hopefully it has been fixed in the later service packs?
TimLangner
I don't know if it has been fixed because I simply uninstalled PerfQA_Analyzer and haven't used it since.
