Cannot lad xml recordset to non simple feature class or table in ArcCatalog.
3142
02-22-2013 09:18 AM
MichaelMiller2
I am attempting to load data into a feature class schema that resides in SDE. After right clicking on the empty feature class. I select Load>Load XML recordset document and it displays an error "Cannot lad xml recordset to non simple feature class or table in ArcCatalog."  How do I interpret this error message? What is a "non simple feature class? Are there other methods that I'm not aware of to accomplish loading data into a schema only feature class?
CraigGillgrass
What version of ArcGIS are you using?
Can you describe the target feature class you're trying to load data into?  Is it in a Topology, Geometric Network or other advanced dataset?  Does it have relationship classes, if so what kind?
thanks,
MichaelMiller2
thanks,
It's ArcGIS 10.0 and there is no topologym etc. Straight SDE dataset with a bunch of domains.  I think the problem stems from the XML file I'm trying to load doe snot have the exact same schema as the schema I attempting to load it into. I'll confirm once I receive the new XML file form the developer.
