Query on a Date Field with LIKE
1133
12-03-2012 08:55 AM
JoeBorgione
I've exported a table from a SQL Server database into a personal geodatabase.  I need to query by a data field and can't quite figure out what I need to do when using a 'like' statement.
The date field in question looks like this:
10/6/2011 7:08:19 PM
There are thousands of records that have 10/6/2011 as the date.  So I tried:
[date_field] like #10/6/2011 *# etc, but I'm told the syntax is wrong.
I can use the equals statement like this:
[date_field] = #10/6/2011 7:08:19 PM#
and it's good to go.  But of course that's just one record...
Any suggestions are appreciated.
That should just about do it....
JakeSkinner
Esri Esteemed Contributor
Hi Joe,
You could use the following expression:
[DATE_FIELD] > #10-06-2011 00:00:00# AND [DATE_FIELD] < #10-06-2011 23:59:59#
This will select all the records with a date of 10/6/2011.
JakeSkinner
Hi Joe,
JoeBorgione
Thanks Jake; I did something similar and it worked out....
