Query Layers - Geometry not drawing from Oracle Spatial
1051
10-11-2012 08:26 AM
ChrisBeaudette
We are having the exact problem posted at this thread from the 'Desktop General' forum.  Thought this forum might have insights.
Chris
BenLin
Hi Chris,
Not sure if you have already resolved the issue or not. Could you please post your SDO table DDL syntax here? Like:
SQL> conn test/test@mydb
SQL> set long 999999
SQL> set head off
SQL> SELECT DBMS_METADATA.GET_DDL('TABLE',u.table_name)
     FROM USER_TABLES u where u.table_name = 'STREETS_SDO';
SQL> set head on
SQL> select distinct a.shape.sdo_gtype from test.streets_sdo a;
SQL> select distinct a.shape.sdo_srid from test.streets_sdo a;
SQL> select * from user_sdo_geom_metadata where table_name = 'STREETS_SDO';
Ben L.
