Publishing Data Interoperability tools with ArcGIS for Server
2428
06-15-2017 03:17 AM
SriHarsha
I am looking for support on  Publishing Data Interoperability tools  and consuming those as REST/SOAP services. Can any one know  Enterprise level  implementation on  server side please share help resources.
JayantaPoddar
Did you check the steps in Publishing Data Interoperability tools with ArcGIS Server?
Think Location
SriHarsha
Dear Jayanta thank you for reference, I gone through the help resource and its helped me a lot. After that I tried to consume as REST but it is failing. I rechecked Extinction on server side also , its authorized. while working with desktop its working fine after publishing in to the server it failing.. what could be the reason I am unable to figure out.
JayantaPoddar
What error are you getting when you run the GP service?
Think Location
SriHarsha
while using "parameters are not valid" error is coming. I am thinking that input parameter file format or else arcgis server version comparability. Server with 10.4 and my desktop 10.3 is this will be a issue?
JayantaPoddar
Thank you for the details. According to Compatibility of ArcGIS 10.4.1 for Server with earlier versions—Documentation | ArcGIS Enterprise
  • If you're publishing a geoprocessing service, the ArcGIS for Desktop version must match ArcGIS for Server.
Think Location
