Problems with overlaps and creating seamless mosaick
2069
08-01-2016 07:19 AM
MattShaffer
we have over 250 rasters of 1937 imagery to mosaic but we are having problems making it seamless.
the flight lines were not flown at the same elevations. is there any way to create a seamless mosaic?
DanPatterson_Retired
are there errors? do they have spatial references?  There is an analyser section in this link,
Creating a mosaic dataset—Help | ArcGIS for Desktop
MattShaffer
for some reason the bit signature changed during the mosaick process. that was the major error i recieved which i think is why it did not turn out seamless.
ModyBuchbinder
You can put rasters with different pixel depth or different number of band in a mosaic but it usually looks bad.
You better change all your rasters into 3 band true color (8 unsigned bit) and then create the mosaic.
The CopyRaster GP tool can help you to do it.
Have fun
