Problem with US Address One Range Geocoding in ArcGIS 10.0 SP4
3154
01-17-2013 06:14 AM
heathbishop2
I'm not sure if I am missing something here, but I am creating an address locator using the US Address - One Range style.  The required fields (noted with an asterisk) include "Side of the Segment" which, according to any documentation I have read, shouldn't be required.  The only required fields should be From address, To address and street name.
Any help is appreciated,
Heath
JasonHrubizna
Hi Heath, I came across this problem too.  In order to work around the Side of Segment requirement, I made a dummy field to use for this.  I populated it with all "L" values and it seems to be working for me. I needed to lower the candidate requirements though.
