Problem splitting lines to points
1234
05-23-2011 02:40 PM
HNicholson
I am having a problem with the very simple method of splitting GPS tracks (line shapefiles) to points. I do not use code, so am reliant on the editor toolbar. The edit pointer will not select the line. Even if I manually highlight the line in question, the toolbar does not give me the split option.
I have done this before, but cannot remember what I am missing out.
Please help!
TimothyHales
Esri Notable Contributor
You cannot split a polyline file into points without having it create a new shapefile as they can only store one geometry type.  Try the Feature Vertices to Points tool to turn a line into points based upon its vertices.
HardolphWasteneys
If the split tool does not activate when you select the line then it is not a feature class in your editing workspace.  REstart your edit session and find the right workspace (gdb, folder etc.) containing it.
H
