Problem generating schematic from geodatabase feature class
2457
04-25-2016 07:02 AM
EricArmitage2
Hi.  I'm trying to get started generating schematics from a simple geodatabase line feature class but having problems.  I've loaded the feature class into my MXD and then selected "generate new schematic diagram" from the Schematic toolbar. However the "Generate Diagram From" dropdown is blank and I can't select the feature class.  Any idea what I'm doing wrong?
DanPatterson_Retired
EricArmitage2
Hi
It’s a very basic feature class of rail links so I guess that’s a network dataset??
Eric
Eric Armitage
Data Analyst – Schematic Network
Asset Information: to inspire & enable through the power of data
First Floor, Willen, The Quadrant MK, Elder Gate, Central Milton Keynes, MK9 1EN
T: 01908 783269
E: eric.armitage@networkrail.co.uk<mailto:eric.armitage@networkrail.co.uk>
it is just a polyline featureclass, unless you make it something different
What are geometric networks?—Help | ArcGIS for Desktop
What is a network dataset?—Help | ArcGIS for Desktop
EricArmitage2
So I have to create a network from the featureclass using the following
1. Right-click the feature dataset that will contain the network.
2. Point to New.
3. Click Geometric Network
So I’ve created a new schematic dataset in the gdb but when I right click on it then “new” I only see “Schematic Folder”. I don’t seem to have an option to create the Geometric Network??
