I'm using the latest. 10.0, Service Pack 3.
I found another issue. When creating a multiversioned view, the sde command "sdetable -o create_mv_view" , it creates the view and among other things, it also adds three triggers named v32_delete, v32_insert and v32_update. These triggers contain a call to the stored procedure SDE_get_globals. This stored procedure doesn't exist. At least in my two running SDE databases. When ever I attempt to insert into the multiversioned view, I get an error that says cannot find stored procedure <database>.<schema>.SDE_get_globals.
Has anyone else created multiversioned views and if so, do you have this stored procedure?
