Parcel Fabric and Representations
2392
10-26-2011 03:36 PM
JeffMorgan
Our Parcel Lines have four different representations associated with them - can these representations be added to the Parcel Fabric Lines? Is there a different way the fabric shows representations?
I'm new to the Parcel Fabric so any kind of direction is appreciated.
JasonCamerano
You can set up a domain on the Geodatabase to match your custom types and assign that Domain to the Type field of Lines.  From there you can then Symbolize the Lines Fabric sublayer to the Type field and then it will be represented in the map.
If you are looking to import this from source data you can add a field to the Fabric prior to the import and name it the exact same name as your "representation" field on your source data and also make sure the new field is the same type as your "representation" field.  Once you import the data all your data will be carried across.
If you have further questions or if you want more information on how to preform these steps I have listed please let me know.
You can also email me:  [email protected] for a faster response.
